It is currently Mon Dec 10, 2018 5:13 am
Post new topic Reply to topic  [ 1 post ]
 factory skid nutserts 1 hour fix NO welding reqired
Post factory skid nutserts 1 hour fix NO welding reqired
I replaced 5 of my nutserts on my 99 TJ today in 1 hour.
1 hour of labor, once you have tools, supplys, and new parts.
Here is how is works
Tools
Bottle jack.
Sawzall with good blade
7/16x6  grade 8 bolts and nuts for the rear 4 bolts
7/16x5  grade 8 bolts and nuts for the front two bolts.
old 7/16 steel wheel lug nuts
3/8 drill bit Not required but make drilling easyier
7/16 drill bit at least 6 inches long.
Angle grinder might possibly be needed
first if the bolts will back off at all do so.
place the bottle jack under the skid.
Then if you can get the sawzall blade to the bolt shank between the factory skid and frame cut the bolts there.
Then jack the skid back up in place.
Take a screwdriver and push bolt/nutsert combo up in the frame.
Then drill straight up though the top of the frame
And install a lug nut flat side down of course on each bolt.
bolt the skid back up to the bottom of the frame.
Real men don't wear Bowties
99 TJ Sahara 4.0 5-Sp Trail Rider
06 LJ 4.0L six speed My DD
90 XJ Project F-XJ (Ford-eXtreme-Jeep!!)
94 F700 U-RV RV+Tow rig 5.9Lcummins /6 sp
77 F150 351M4x4 not stock 4-Sp (farm/Tow Mule)
Sun Jul 19, 2009 9:53 pm
Users browsing this forum: No registered users and 1 guest
