It is currently Mon Dec 10, 2018 5:23 am
Post new topic Reply to topic  [ 5 posts ]
 Ac only blows out defrost/ cruise does not work/ rough idle
Vehicle: 00 XJ, 96 XJ Up country
Post Ac only blows out defrost/ cruise does not work/ rough idle
ok. Was a jeep tech for several years, just joined the site and thought i would put my time in and help a little with tech.
Common problem on cherokees (xj)
Symtoms: Ac or heat only blows out of defrost. Crusie control will not activate. Rough idle, low idle.
Problem: Vacume hose, located under battery tray has been eaten through with batt acid. Since the engine vacume controls all of the above functions. You should have all the above issues, given everything else is working properly.
Correction: Generally make sure current battery is clean and not spilling out acid water. Take a small peice of vacume tubing, cut plastic line and make a easy splice. Can pick up tubing at advanced cheap. Simple 30 min fix. Sometimes required to take out battery if hose hole location is to hard to reach. Thanks  let me know if this helps with a easy post!
-96 XJ Up Country 2" lift, 30s. 00 XJ SE 2" lift 30's
-XJ, Just as good as a Wrangler...and can haul 4 people, my gear, and Theirs!
-"You cant make it up that! Obviously you havent driven a jeep!"
Fri Jul 08, 2011 5:06 pm
Post Re: Ac only blows out defrost/ cruise does not work/ rough idle
It could also be the vacuum bottle mounted to the back of the front bumper.
Fri Jul 08, 2011 6:14 pm
Yes, any vacume leak can cause this issue, my point was this is a very common problem with the battery acid draining down onto the vacume hose. I have actually never replaced a vacume bottle on a xj in the 8yrs i have worked on them. But that is not to say it doesnt happen. The first place i always look when these symptoms are apparent is the hose at the battery. It saves alot of diagnostic time and $ for people.
Fri Jul 08, 2011 10:02 pm
The bottle on my XJ was busted when I bought it.
Fri Jul 08, 2011 11:24 pm
Site Admin
Vehicle: 2000 WJ v8
this info is exactly the same for WJs as well, except the line under the battery is normally cracked, not eaten up by battery acid.
~Aaron
J-rod wrote:
When a good driver and good spotter join up magic happens.
It's ok to mix apples and oranges, so long as they're wired in series with a banana between them.
Sat Jul 09, 2011 11:34 am
Users browsing this forum: No registered users and 1 guest
