It is currently Sun Jan 20, 2019 11:49 pm
Post new topic Reply to topic  [ 7 posts ]
 Broken seat bracket bolts
Post Broken seat bracket bolts
I broke the 2 bolts that hold the passenger side rear seat bracket on. I tried drilling them out.  Now both bolts have broken bits in them. I get see the welded nuts underneath. My plan is to remove the welded nuts and replace them with grade 8 bolts with lock nuts. What's the best way to remove the welded nuts if you don't have access to a welder or torch?
Tue Sep 22, 2015 10:06 pm
Vehicle: 05 LJ Wrangler
Post Re: Broken seat bracket bolts
A bigger drill bit.
05 LJ
14 JKU
15 DART
Do you even wheel Bro?
Wed Sep 23, 2015 12:40 am
Vehicle: 2009 JK Rubicon
Thin cutting blade on a grinder.....maybe?  :idea:
TO THE WOODS
Wed Sep 23, 2015 7:13 am
Vehicle: 96 xj white 4dr
Find the spot welds and drill out. Flat chisel  them free or cutting wheel free...
J.ust
E.veryone
E.veryday
P.laying
..,=====,___
//__l_l_,\____\,__
l_--\_l__l---[]lollol[]
_(o)_)__(o)_)--o-)_)___ winch, some lights, 31s, some looks, unlocked, 4.0 i6,
Life is not a race, there's no need to come in first to finish!
Wed Sep 23, 2015 3:47 pm
I put a socket/ratchet on the welded nuts, applied some pressure and they popped right off. I always make things tougher than they need to be.
Sat Sep 26, 2015 6:55 pm
Vehicle: 1993 YJ Sahara
I have this problem on my yj. My brother snapped them and i want the rear seat in there. Hopefully they are easy to reach like your tj.
Hey, i'm Dave
Mon Feb 15, 2016 11:16 am
Vehicle: 10 JKU 86 CJ7
Just a little bolt triva grade 8 bolts are hardened and will shear or snap when subjected to sideloading. I would use grade 5 on seat mounts they bend before snapping.
And try a carbide drill bit on the broken bits in the hole. Drill slow.
Good luck.
Mon Feb 15, 2016 9:29 pm
Users browsing this forum: No registered users and 8 guests
