JeepinWV.com - View topic - Powertrax Grip Pro versus Detroit Tru Trac?
It is currently Tue Jan 22, 2019 6:48 pm
Post new topic Reply to topic  [ 17 posts ]  Go to page 1, 2  Next
I Jeep, therefore I am.
Vehicle: 2005 Wrangler LJ
Post Powertrax Grip Pro versus Detroit Tru Trac?
Both are mechanical LSDs (no clutches) and both have a similar warranty.
I have had good experiences with the Detroit Tru Tracs in the past, but am considering the Grip Pro for my new (to me) JKU.
Anybody have any experience with Powertrax products?
Thanks!
LIVING IS:
Living is a thing you do
now or never.............which do you?
Fri Aug 19, 2016 2:34 pm
Post Re: Powertrax Grip Pro versus Detroit Tru Trac?
Oh, and the Grip Pro is about $100 cheaper than the Detroit.
LIVING IS:
Fri Aug 19, 2016 2:37 pm
For the amount of money those cost, I'd probably go with the known brand for only $100 difference. That being said, I have no experience with either.
Fri Aug 19, 2016 3:54 pm
Some days it just doesn't pay to chew through the straps.
Vehicle: 01 TJ
my Detroit in my D44 has been flawless since i put it in 2006...  spend the extra $100
Fri Aug 19, 2016 6:02 pm
Vehicle: 1976 CJ-7
Is this a Manual or Auto 2012 JKU?  Rumor has it that if it is an auto you cannot put a locker in it or it will cause the trans to go into limp mode. To my knowledge there is no fix for this yet. I been waiting for it as I want to lock my 2012 JK's rear axle. The next question is, what axle are your looking to put it into? Front or rear?
HIGHLANDERCJ-7
The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government. -Thomas Jefferson
Mon Aug 22, 2016 10:52 am
I had great luck with the TruTrac that I ran. Would run one again.
Mon Aug 22, 2016 11:44 am
Was actually looking at putting it into both axles.  I don't want a full locker.  I had a 2007 with Tru Tracs in both axles and it went everywhere I wanted it to go.
Where are you getting your information on it putting the transmission into limp mode?
LIVING IS:
Wed Aug 24, 2016 10:43 am
Vehicle: 1976 CJ-7
Here's one story:
http://www.jkowners.com/forum/modified- ... issue.html
Another guy wrote :
I love a good mechanical locker... I have a 2013 MOAB JKU and have a yukon grizzly locker in the rear. You will randomly get a limp mode problem with these lockers when the wheel speed sensors don't read what they should when cornering. The main problem seems to be coasting when turning the wheel more than 180* while coasting or under light throttle. I would say in the 15k miles since installing it and I have only had the limp mode a dozen times and a simple cycle of the ignition is all it takes to cure it.
HIGHLANDERCJ-7
Wed Aug 24, 2016 10:52 am
Vehicle: 1976 CJ-7
Also a friend has this one for sale dirt cheap:
http://novajeepers.net/index.php?topic=25054.15
HIGHLANDERCJ-7
Wed Aug 24, 2016 10:54 am
Here's one story:
The Yukon Grizzly is a full locker though.  I'm talking Detroit Tru Trac, which is an aggressive LSD, but not a full locker.
And yes, that is a sweet deal on a Yukon Grizzly.  If I were interested in a full locker, I would be all over that.
LIVING IS:
Wed Aug 24, 2016 10:58 am
OllllO
I've been happy with the Truetracs. No experience with the other.
Sat Sep 10, 2016 5:11 pm
Vehicle: 2000 Jeep Wrangler
My understanding is that the true trac will not cause the limp mode issue since it's still technically a limited slip,, but the standard Detroit locker will in some situations..
2000 Jeep TJ; locked Dana 44 rear, Dana 30 front w/air locker, Full Traction 6" long arm lift, 35"X12.5"X15" wrangler MTRs, Warn 9500HS winch, Atlas II transfer case.
Sat Sep 10, 2016 10:25 pm
OllllO
The Truetracs are very comfortable on the street. I wouldn't expect any issues with them on an auto.
I ran them front and rear on my 13 (manual though) without issue summer or winter. The one for the front 30 will go in my wife's 14 auto when it gets the 4.56 gears.
Sun Sep 11, 2016 4:45 am
Detroit Tru Tracs are installed front and rear, along with 4.56 gears.
Had them about a week and am very pleased.
LIVING IS:
Mon Sep 19, 2016 3:44 pm
Who did your gears?
Mon Sep 19, 2016 8:31 pm
Users browsing this forum: No registered users and 12 guests
