It is currently Mon Aug 20, 2018 6:34 am
Post new topic Reply to topic  [ 1 post ]
 My old crawler king
Vehicle: 1994 Yj
Post My old crawler king
Built it for 2 years always changing stuff. Then needed money and traded it off to Moore4x4 on here which lead to me having a welded chrysler 8.25.
Had a 15 inch wheelbase.. Was stretched with 125mm bent crawler links. Had aluminum all over the place and comp cut body.. hpi rock grabbers in rear axial lizards front.. wheel spacers...drooped integy aluminum shocks...stock chassis. Had a novak rooster crawler esc dual hitec 645 servos (front and rear steer) depending on my mood a 20,45,or 55 turn motor. Spektrum dx3e radio... was the coolest build I ever done. Only actual build i ever done. 90 degrees of flex. everything came from spare parts I had. no custom work except I used a stock Crawler king bumper as a spacer so my 3 link bar would reach the chassis. It was 95% done there was a few weak points but it held up good.
Rear steer. It was sloppy but it did what it was supposed to. Most of the time.
That's a 2-liter for reference.
Fri Jul 15, 2011 12:53 am
Users browsing this forum: No registered users and 1 guest
