Post your Rig and Mods.
91JEEPNUT
Re: Post your Rig and Mods.
Post by 91JEEPNUT » Sat Feb 02, 2008 10:08 am
1991 YJ
350 Chevy V-8 5spd
33 x 12.50 MT
Locked 8.8 rear axle with disc brakes
Warn M8000
home made front and rear bumpers
4" super winch lift
More to come
91 YJ, 4" lift, 33x12.50 M/T, Warn M8000, Home made bumpers, 350 Chevy with 5 spd, ford 8.8 with locker and disc brakes, more to come
nitecop
Post by nitecop » Sat Feb 02, 2008 7:55 pm
M 99 Sahara with a 5 speed
Lockright locker in the front Dana 30
Teraflex discos
Uniden CB
Euro Brush guard (modifyed slightly for winch and strength)
Ramsey Rep 8000 Winch
Roller fairlead (moded with brass bushings and greasable)
Homemade winch mount plate
Homemade rear 2 inch reciver hitch(inside stock bumber)
Homemade drag link reinenforcment (Cost $3 in steel)
Homemade Front diff cover protection(extra cover welded to stock cover)
Streering box and gas tank skids
15x8 steel D-hole wheels
Rock hard full bolt in cage kit
32x11.50Rx15 Mastercraft Coursior MT tires
BDS 2inch spring lift kit
Rrough country adj frt track bar
2 Hardtops 1 is a sarfari style hard top.
Dynomax cat back exh system
Future stuff
Install my D44 with a tru trac for the back that I have.
And make my stock trans and TC case skid smoother on the bottom with some plate and plenty of welding.
Real men don't wear Bowties
99 TJ Sahara 4.0 5-Sp Trail Rider
06 LJ 4.0L six speed My DD
90 XJ Project F-XJ (Ford-eXtreme-Jeep!!)
94 F700 U-RV RV+Tow rig 5.9Lcummins /6 sp
77 F150 351M4x4 not stock 4-Sp (farm/Tow Mule)
drewtoyandchev
Post by drewtoyandchev » Sat Feb 02, 2008 11:16 pm
my 1984 toyota
4" lift
35" boggers
in the next few weeks:
5.29 gears
spool or welded rear... havent decided yet
chop fenders
chop rear frame and flatbed
wheel spacers
Last edited by drewtoyandchev on Sun Feb 10, 2008 2:18 pm, edited 1 time in total.
1999 silverado d.d./ tow rig
86 toyota 4 runner, sas, 36s, 5.29s, bumpers and sliders http://www.highcountryoffroad.org
1_TON_YJ
Post by 1_TON_YJ » Sat Feb 02, 2008 11:21 pm
1995 4cylinder 5speed from the factory.
Now:
Motor: 1996 cherokee 4.0
Tranny: AX-15 with Center force dual friction clutch
Transfer Case: Dana 300 t-case, flipped, twinsticked, 4:1 gears, and 32 spline outputs front and rear.
Front Axle: HP dana 60 front axle, 5.38 gears, lockright locker, Yukon chromo 35 spline inner and outers, and warn premium hubs.
Rear Axle: Dana 60 rear, 5.38 gears, spool, and Yukon chromo shafts.
Steering: Poison Spyder customs hi steer arms, 1.5'' .250 wall tie-rod and drag link, AGR hydro assist Converted to a P-series pump.
Suspension: 2.5 BDS leafs, 1.5 shackles, and SOA.
Driveshafts: Homemade with 1350 Joints
Tires: 41x14.50xR16 Radial Iroks
Wheels: Cragar soft 8s, with custom KORE beadlocks
Misc: Super Winch EPI 9k Olyimpic rock sliders Tomken rear bumper 2 inch body lift (to clear t-case) Hiflow aluminum radiator.
95' Wrangler 35 spline 60's atlas 42s
01' XJ HP44/FF60 6speed manual 5.13s 35 LTBs
98' Wrangler Sahara Reincarnation DD/weekend warrior
06' Quad Cab Cummins Edge juice with attitude, K&N Intake, Muffler delete = Toy hauler
http://www.americanfourwheeler.com
1_TON_YJ
Post by 1_TON_YJ » Sun Feb 03, 2008 12:02 pm
Nice pics! I havent seen those, thank you!
Jeeper8650
Post by Jeeper8650 » Sun Feb 03, 2008 4:14 pm
2001 Tj 60th edition
4.0L- AEM intake custom exhuast
Nv3550
Atals 4spd
1350 balanced shafts
hp60 front- 5.13, ARB, 35 spl yukon chromos, warn premiums, rockcruaher diff cover, Crossover steering using .250 wall chromo links, High clearance brackets, custom panhard.
14boltrear- 5.13 detriot disc braked with eldorado calipers, high clearance brackets.
Suspension- Custom 4 link, stretched out to 104''(3'' front/ 7'' rear), frame notched and plated to move couls back.
Warn 9.5 ti
Psc rockers and tube fenders
Comp cut rear
Rci 2161A fuel behind back seat modified to accept factory in tank pump
Dodge 3500 MC for one ton brakes
Piaa driving lights
H4 headlight conversion with 130w bulbs
optima yellow top
toys by troy bumper modified for wheelbase
39.5X13.50R17 Iroks on 17'' H2 alloys
Arb on board air source
In the works before Moab in May:
Full cage
POS full hyro steering
link and coilover front
How it all started:
http://s110.photobucket.com/albums/n88/ ... CN2459.flv
01 tj with some stuff.
jeepers
Post by jeepers » Mon Feb 04, 2008 2:00 am
96 xj
7.5" RE lift W/ 3-link long arm
Jcr off road front bumper
Jcr offroad rear bumper
Jcr 1-ton steering
powertrax rear locker
8.8 rear axle w/ welded tubes & disc brakes
Yukon 4:88 gears
Bored throttle body
Throttle body spacer
RE thumb throttle
Black Rock krawler wheels
35/12.50/15 BFG M/T's(Trail setup)
rubi wheels w/ Mtrs (D.D setup)
cobra cb
On-board air
96 XJ long arms, lockers and 35's--RIP
93 S-10 LSX powered (under construction)
98 2500 tow rig
The white thing on the left
BacklashXJ
Post by BacklashXJ » Wed Feb 06, 2008 11:35 am
2000 XJ sport. Rustolium black / Patriot Blue.
the good:
4.0L AMC 242
AW4 Automatic tranny
NP231 transfer case
High Pinion Dana 30
Ford 8.8
4.56 precision gears
aussie locker front
Powertrax lock rite rear
5.5" suspention lift
Rock Krawler 3 link front long arm system
35" BFG MT's
Custom 6 point cage
custom stinger front bumper
custom rear bumper / tire carrier
summit racing seats
RJS racing harnesses w/ cage tie ins
120v conversion outlet
Sony xpold head unit
Polk audio 6" composite speakers
Bazooka tube sub
herculine'd floor
bored throttle body
optima battery
TnT customs Frame stiffeners w/ cage tie-ins
TnT customs Heavy duty track bar
Off Road Only U-Turn Steering system
Durango steering box swap
steering box brace
Cobra CB
Push button start with 6 switch panel
Hellas
custom shifter plate and shifters
custom sound bar
SYE with front DS in rear
Pics:
2000 Jeep Cherokee Patriot Blue/Rustolium Black
custom 4-link front and rear, 16" travel coilovers, PSC full hydro, 38's, 5.13's locked and loaded D60/14BFF, D300. WIP.
2001 Mitsubishi Eclipse Patriot Red
5spd, bolt-ons and some upgrades. DD.
Forbes
Vehicle: Pair of Nike's.
Post by Forbes » Wed Feb 06, 2008 10:15 pm
All stock on 31 BFG AT's.... Gotta start somewhere I guess.
77jeepcj
MOR President
Post by 77jeepcj » Thu Feb 07, 2008 4:33 pm
heres my lil one with a few bolt ons
President
ifixjeeps
Post by ifixjeeps » Thu Feb 07, 2008 8:15 pm
a few pics of my heep. Some modifications listed at the bottom.
96 XJ 5.5"RE lift, 33x12.5"Trxus mts on soft 8s, Proto fab fr bumper, MM9500se winch, olympic offroad roof rack, RE hack-n-tap and shaft, rear ARB air locker, ZJ rear disc brakes, and a few other mods.
mdslngr77
Vehicle: Samurai/tracker hybrid
Post by mdslngr77 » Fri Feb 08, 2008 4:25 pm
88 Samurai
custom stacked rears up front
custom stcked cj fronts in the rear
missing links front/rear
custom front/rear bumper tire carrier/sliders/skid pan
sport cage w/safarai cover and fiberglass front section
durabak paint all over
31-10:50-15 hitec's
5.13 r&p, lockrite front, mini spool rear
4.91 t-case
8K Champion winch
Samurai power -- 4 squirrels and one nut
rog97
Post by rog97 » Sat Feb 16, 2008 9:45 am
1997 4 banger
Onboard air
Hand throttle
Warn M8000 winch with synthetic line, incab winch controller
Adjustable upper/lower control arms
3 inch suspension lift, 1 inch body lift, 1 inch motor mount lift. quick disconnects
Kumho 32 MT AR wheels (Wish I'd went 33)
Tera lo 4:1 with 2wd low, AA SYE, TW shafts front and rear
Dana 30 front super 30 with ARB locker, Ford 8.8 rear with Eaton E-locker 4.88 gears
Flat belly skid, Engine skid, Radiator skid, Steering box skid, Kilby gas tank skid, Rocker guards, rear corner guards, windshield guards. M.O.R.E roll cage, LOD rear bumper, Front winch bumper
Viking soft top, door window sliders
97 tj with a few non-chrome mods
rog97
Post by rog97 » Sat Feb 16, 2008 9:54 pm
Thanks, I'll snap a few more pic's.
01amberfirewv
Vehicle: 2001 TJ, lifted, locked and...
Post by 01amberfirewv » Wed Feb 20, 2008 7:12 pm
2001 Amber fire Jeep Wrangler SE, 5-speed
Drivetrain 2.5L 4cyl
Rocket-parts intake
4.0TB
Magnaflow muffler
Slip Yoke eliminator
Tom Woods drive shaft
Lights
Hella 500 driving lights
brakes
Performance friction pads
Lift
Old Man Emu heavy duty springs, shocks and track bar relocator
and the important stuff
Tires
31" TrXus Mts on 15x7 American Racing Sliders
Armor
AtoZ Fabrication rocket gaurds
AtoZ Fabraction short corner gaurds
Warn steering box skid plate
EMP gas tank skid plate
Custom rear bumper/tire carrier
Herculinded tub
Axles
Dana 30 4.88 gears, Auburn ECTED LS/Magnetic locker
Dana35 4.88 gears, Super35- 30 spline shafts, Detroit locker
Locked, lifted and armored TJ,
E46 BMW 330i, M3 CSL's, Magnaflow, tinted windows, clear corners, black grills
Ford Flex SEL AWD, tinted windows, Thule rack system
