DIY Quick Jack
Any technical talk for other vehicles goes here
Locked
J-rod
DIY Quick Jack
Post by J-rod » Wed Nov 30, 2011 10:43 am
so making a DIY Quick Jack with this jack and 3" body block.
I dont like how the bolt head will create a place for a point load and take the brunt of the weight, as opposed to the body block disbursing the load more evenly.
I dont see a way to countersink the bolt head flush with the body block as the area around the bolt hole is thin wall.
ideas?
Forbes
Vehicle: Pair of Nike's.
Re: DIY Quick Jack
Post by Forbes » Wed Nov 30, 2011 10:57 am
1. Does the cylinder that the bolt goes through go the whole length of the block? you might be able to grind just the cener out a little with a dremel... enough to countersink the nut, or a bolt head....?
2. Can you fit a piece of steel pipe over it like a sleeve perhaps? as the jack gets higher, it will slide down a little, but you get the point... that will put a lot of down force on the jack arms though.
3. try to find a steel "cup"... similiar to something like a 2" hole saw.... that you can bolt in the bottom and have the cup facing up.
4. Just buy a real hydrolic floor jack and throw this thing in the garbage. :) lol
ZiGGY
Vehicle: 2014 WK2, 2008 JK
Re: DIY Quick Jack
Post by ZiGGY » Wed Nov 30, 2011 11:02 am
I agree seems like a bad idea... There so easy to tip over and hurt you not modified.
WVHeep94
Vehicle: 2009 Tacoma
Re: DIY Quick Jack
Post by WVHeep94 » Wed Nov 30, 2011 11:02 am
A) Drill bit diameter of washer. Drill to depth needed. Done.
B) Smaller drill bit, then finish with dremel.
God invented Firefighters so cops could have hero's too.
J-rod
Re: DIY Quick Jack
Post by J-rod » Wed Nov 30, 2011 11:07 am
Forbes wrote:1. Does the cylinder that the bolt goes through go the whole length of the block? you might be able to grind just the cener out a little with a dremel... enough to countersink the nut, or a bolt head....?
1. yes it does. I might go put the block on the drill press after work and see if I can drill out the center a little bit. That might let me run a shorter bolt and washer and keep it below the top. :think:
4. :tupton: this is for quick jobs and another thing to keep in the trail bin.
J-rod
Re: DIY Quick Jack
Post by J-rod » Wed Nov 30, 2011 11:09 am
ill try to countersink it but it is thin wall in the center for the bolt.
Vec
Vehicle: 01 TJ
Re: DIY Quick Jack
Post by Vec » Wed Nov 30, 2011 11:10 am
En este mundo hay dos tipos
Los de armas cargadas y los que cavan
speedy
Vehicle: 2011 jk
Re: DIY Quick Jack
Post by speedy » Wed Nov 30, 2011 11:10 am
try using a carrage bolt
2011 jk on 35s
2010 jku
J-rod
Re: DIY Quick Jack
Post by J-rod » Wed Nov 30, 2011 11:12 am
Vec wrote:Image
Hey Joe....bite me :tupton:
ZiGGY
Re: DIY Quick Jack
Post by ZiGGY » Wed Nov 30, 2011 2:16 pm
lol
Locked
