Smacker axle upgrade??? opinions please
Any technical talk for other vehicles goes here
mdslngr77
Vehicle: Samurai/tracker hybrid
Post by mdslngr77 » Thu Dec 19, 2013 10:45 pm
Question : I am debating on my axle upgrade. I have found Scout D44s and Toyota FJ axles. The fjs will be a couple of inches wider, will come with lower stock gears but will still need regeared for my liking. I'll have to get new wheels or spacer/adapters for my wheels. The steering will adapt easily as will the driveshafts.
The 44s are the right bolt pattern, about the perfect width. Will definitely need regeared and most likely will have to have new carriers for the gears. The steering is questionable on adapting easily to my setup. The FJ has larger ring gear .
Gear options are pretty much the same - I believe upgrades are more readily available for the FJs.
What do ya'll think?
Samurai power -- 4 squirrels and one nut
ledzep_06
Re: Smacker axle upgrade??? opinions please
Post by ledzep_06 » Thu Dec 19, 2013 10:54 pm
Id go Yota (and not just because I own one.) Id say the extra width could be beneficial where the smacker is a bit more top heavy, third members are stout, and if you wanted to get different rims instead of adapters keep in mind toyota and six lug Chevy had the same bolt pattern (dont know if they still do) so some cheap steelies shouldn't be that hard or pricey to pick up
One Ton Swamper
Vehicle: 2015 Challenger Scat Pack
Post by One Ton Swamper » Fri Dec 20, 2013 7:57 am
60's :bigthumb:
Standing 112 miles from the best wheeling in WV.
Shaun
Vehicle: 2011 Jeep JK
Post by Shaun » Fri Dec 20, 2013 10:07 am
One Ton Swamper wrote:60's :bigthumb:
X2. Lol
Are you a regular forum user that wants to become a WV Jeep Club Member? Submit your application here http://www.jeepinwv.com/forum/application.php
jbain
Vehicle: 1985 XJ Truggy
Post by jbain » Fri Dec 20, 2013 10:50 am
for no bigger than that rig is I'd opt for a Dana 30HP front and a Ford 8.8 or a Chrysler 8.25 rear..... Narrower and easier to put on a standard car trailer..... However, if you went with 60's the axles would weigh more than your rig so you could drive it almost vertically and it wouldn't roll..... LOL
ICF PRESIDENT
Post by ICF PRESIDENT » Fri Dec 20, 2013 10:54 am
Are the toys fj 40s or 80s?
Standing 150ft from the best offroading in wv.
mdslngr77
Post by mdslngr77 » Fri Dec 20, 2013 11:04 am
I believe they are 40's going to look for sure this weekend..
jeepjockey
Post by jeepjockey » Fri Dec 20, 2013 1:24 pm
jbain wrote:for no bigger than that rig is I'd opt for a Dana 30HP front and a Ford 8.8 or a Chrysler 8.25 rear..... Narrower and easier to put on a standard car trailer..... LOL
You might as well leave the stock axles in. This would be a waste of time and money..
Go with the yotas.
ICF PRESIDENT
Post by ICF PRESIDENT » Fri Dec 20, 2013 11:10 pm
If there 40s or even 80s the dif is offset just like a sammy
the 40s birfields are like mini truck axels
the 80s are massive like comparing a 60 to a 44
mdslngr77
Post by mdslngr77 » Sat Dec 21, 2013 2:38 am
did not know about the offset.. that'll make life alot easier... I do believe Toys are in my future..
ICF PRESIDENT
Post by ICF PRESIDENT » Sat Dec 21, 2013 11:14 am
Hey brad if you decide to link it im selling brackets
jbain
Post by jbain » Mon Dec 23, 2013 12:05 pm
What size tires do you plan to run Brad..... and aren't you running Samari stuff now?
mdslngr77
Post by mdslngr77 » Mon Dec 23, 2013 5:41 pm
Just running my grooved 33's for now - Might bump up to 35's but no bigger than that. I am running sammi stuff now and I have been destroying it. Mutiple broken birfields, one grenaded front locker, and stripped rear ring and pinion.. destroying the little stuff is the whole reason I want to upgrade some
jbain
Post by jbain » Tue Dec 24, 2013 8:36 am
I would say don't build any more axle than your gonna need.... seems the 40's need alot of upgrades to be strong which equals money..... I'll stick with the 30/8.8 suggestion because the cost is minimal and regardless of what you hear they're plenty strong enough for 35's. Don't get caught up in the "Pirate Hype" and do a little reading..... My MJ probably weighs twice as much as your rig and I run the hardest trail IVY has locked front and rear with 36SX Super Swampers.... Inexpensive and strong..... no hype.....
jeepjockey
Post by jeepjockey » Tue Dec 24, 2013 9:47 am
I'm not trying to pirate hype anybody. If I was gonna do a swap I wouldn't waste my time with a 30. The 8.8 will hold up fine with 35s the 30 won't last long. I actually know this from experience. You'll find out eventually. More axle than you need is better than a axle that your gonna want to swap out again because it's anemic.
