Hydro assist ram mounting
Any technical talk for other vehicles goes here
jperry7783
Post by jperry7783 » Sat Mar 01, 2014 10:13 am
I put some upgraded steering on my Bronco, 1 ton tre's and 1 1/2" dom. I have a hydraulic ram that works good, I just can't fit the ram on the axle without moving my track bar mounts. I was considering mounting the ram to the frame and the pitman arm.
Like this
My new set up
Is there some major problem I'm missing? Any thoughts on why this is a bad idea?
whitejeeploven
Vehicle: 96 xj white 4dr
Re: Hydro assist ram mounting
Post by whitejeeploven » Sat Mar 01, 2014 9:10 pm
if you want to run ram get a thicker dif and mount ram there and then to tie bar ive seen it done looks like it works good
J.ust
E.veryone
E.veryday
P.laying
..,=====,___
//__l_l_,\____\,__
l_--\_l__l---[]lollol[]
_(o)_)__(o)_)--o-)_)___ winch, some lights, 31s, some looks, unlocked, 4.0 i6,
Life is not a race, there's no need to come in first to finish!
jperry7783
Post by jperry7783 » Sat Mar 01, 2014 9:27 pm
If I do that it will hit the track bar mount when fully extended.
I could mount it below the tierod, but I think it may be easily damaged there.
Post by EricsGreen98Tj » Sun Mar 02, 2014 3:25 am
Thn build a skid that will protect it.
Seems like that's a lot of unnecessary strain to put on a pitman arm...
Anyway that you can mount it to the axle tube and run it straight to the knuckle?
Vec
Vehicle: 01 TJ
Post by Vec » Sun Mar 02, 2014 8:35 am
full hydro steering and half trac the rear drive... that and a SBC on pane, add an MP3 player and that would be the shiznit...
jperry7783
Post by jperry7783 » Sun Mar 02, 2014 10:54 am
The skid idea never even crossed my mind, I'll look into that. It may just make the 60 more of an anchor though with me only running 37s.
Vec, you can do better.
