2012 Jeep JKU Sport from MOAB Industries
Pictures of meets...your Jeep...etc
rdcox23
Vehicle: 2005 Wrangler LJ
Post by rdcox23 » Wed Jun 22, 2016 1:56 pm
Time to start another JKU project.
This one has a nice 6" lift on it already, but virtually nothing else besides the MOAB stickers.
Sent from my SAMSUNG-SM-G870A using Tapatalk
LIVING IS:
Living is a thing you do
now or never.............which do you?
rdcox23
Post by rdcox23 » Wed Jun 22, 2016 2:07 pm
LIVING IS:
rdcox23
Re: 2012 Jeep JKU Sport from MOAB Industries
Post by rdcox23 » Wed Jun 22, 2016 2:30 pm
This thing is a real piece of work.
Neither of the axles are centered under the body. The drag link needs flipped, badly. It's in such a bind that I worry about driving the thing. The bar for the tie rods is an odd u-shape and you cannot adjust it properly. When you try to turn it, it hits the dif cover.
I already have JKS track bars for the front and rear. Now I guess I need a drag bar flip and a heavy duty tie rod bar. Heck, I may just do a high steer kit and be done with all of it. That would solve several problems all at once, but it won't be cheap.
LIVING IS:
ZiGGY
Vehicle: 2014 WK2, 2008 JK
Post by ZiGGY » Thu Jun 23, 2016 8:48 am
Contact NorthRidge
https://www.northridge4x4.com/part/drag ... 21-02-8003
Upgraded all my steering components with Synergy.
14 Jeep WK2 Limited
08 Jeep JK 4D Rubicon - 6.5in lift, 35x12.50 Cooper Discovery SST, Smitty Built Winch, Solid diff covers, Warn rear bumper
Post by J-rod » Thu Jun 23, 2016 11:58 am
ZiGGY wrote:Contact NorthRidge
all my Steering is Synergy too. I second that.
but I buy direct from my buddies there. 8-)
rdcox23
Post by rdcox23 » Thu Jun 23, 2016 1:02 pm
So should I drop your name and ask for a discount???? :bigthumb:
LIVING IS:
Post by SLADE » Thu Jun 30, 2016 5:09 pm
Lose some of the lift, get back into the 3.5"-4.5" suspension lift range. If you need more tire clearance get into flat flares and/or a 1"-1.25" body lift.
You want high steer for anything at 4" or higher.
Make sure you have axle side track bar brackets.
Do not use a drop pitman arm.
Do not use frame side trackbar drop brackets.
Synergy is pretty much a go to for high steer.
rdcox23
Post by rdcox23 » Fri Jul 01, 2016 8:30 am
Already ordered the Synergy stuff. I'm planning on having a patriotic wrenching party over the weekend if anyone is interested. Beer and pizza are on me.
LIVING IS:
ZiGGY
Post by ZiGGY » Fri Jul 01, 2016 10:34 pm
What weekend?
14 Jeep WK2 Limited
rdcox23
Post by rdcox23 » Fri Jul 08, 2016 4:46 pm
ZiGGY wrote:What weekend?
Well I tried to get it done this past weekend. The lug nuts didn't want to cooperate. I have since replaced them and am going to try to work on it some this weekend.
LIVING IS:
rdcox23
Post by rdcox23 » Mon Jul 18, 2016 4:37 pm
Reid racing knuckles and Synergy high steer system are in place.
Still getting some ESP / ABS issues, but I believe that will be solved with a fresh alignment.
Stay tuned.
LIVING IS:
rdcox23
Post by rdcox23 » Thu Jul 28, 2016 1:33 pm
rdcox23 wrote:Reid racing knuckles and Synergy high steer system are in place.
Stay tuned.
A four wheel alignment and a Bilstein steering stabilizer seems to have solved all of my issues.
This thing runs and rides great now.
Time to save up some money for re-gearing and a front locker of some sort.
LIVING IS:
Post by smccollamjr » Thu Jul 28, 2016 1:57 pm
Going with Truetracs again? Have you lowered it any?
rdcox23
Post by rdcox23 » Thu Jul 28, 2016 3:08 pm
smccollamjr wrote:Going with Truetracs again? Have you lowered it any?
I haven't really decided yet, but I liked my set up with the Tru Trac in the last one. It did everything that I wanted it to do.
Not planning on lowering it any. If I can continue to save up, maybe I will buy a D44 for the front or beef up the D30 enough that I could run 37s or bigger in the future.
You never know with me. :bigthumb:
Also need to get the winch sorted out and working properly.
It's a slow, deliberate process.
LIVING IS:
rdcox23
Post by rdcox23 » Mon Sep 19, 2016 3:46 pm
Detroit Tru Tracs (front and rear) and 4.56 gears are installed and running great.
Drive Line Service
They do a great job. Call and ask for Craig. I told him I would try and spread the word for him a little bit.
LIVING IS:
